Brakes problem
2005 Ford Freestyle 6 cyl Two Wheel Drive Automatic
I just replaced the rear brake calibers, rotor and pads. I think I need to bleed the air out of the brake lines. When I press the brake pedal the first time it goes to the floor. As I pump they pedal it gets better. But when I drive I have to continue to pump the pedals. Do I need to loosen the valve on the caliber and pump the brake pedal to get the air out.
Oct 4, 2010 at 4:36 AM
