2007 Ford Freestar whont start
2007 FORD FREESTAR
DJK123
2007 Ford Freestar V8 Two Wheel Drive Automatic
my van will not start but it is turning over it was runing good the day befor
Sep 26, 2010 at 3:53 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 26, 2010 at 1:20 PM
