2005 Ford Freestar Tire pressure warning light
65,000 MILES • 6 CYL • FWD • AUTOMATIC
ALANUVA1957
How do you clear the tire pressure warning light? I get the tire symbol light as well as a digital message to check tire pressure. The tires have been properly inflated.
May 29, 2010 at 12:43 AM
  • 31,937 POSTS
Did you check the spare as well?
mark (mhpautos)
May 29, 2010 at 12:51 AM
ALANUVA1957
[quote="mhpautos"]Did you check the spare as well?
I understand the system does not actually check air pressure, but the level of the vehicle. Wouldn't this eliminate the spare tire from the problem?
Thanks.
May 29, 2010 at 1:06 AM
  • 31,937 POSTS
OK, in that case i would say it would, now this is not a system that i am familiar with, i will have to do bit of home work on this one, if i can't help i will pass it onto a mod who can.
mark (mhpautos)
May 29, 2010 at 1:14 AM
