2005 Ford Freestar rear brake calipers
APES5
Brakes problem
2005 Ford Freestar 6 cyl Front Wheel Drive Automatic
How do I turn the pistons in on the rear brake calipers? They turn out but not in. Is there a adjuster that stops it from turning back?
May 10, 2008 at 2:34 PM
MASTERTECHTIM
  • 4,750 POSTS
there is a special tool you can usually borrow from the parts store. it pushes slight pressure on the piston while turning it back in.
May 10, 2008 at 11:46 PM
LAWMN52
There is a tool, but if it is like the 2004 Freestar, it is not the cube style one, it is the round one. I found mine at Napa for 20.00. I also found that you have to take the piston almost all the way out and then twist it back in. Took alot of hair pulling before I figured it out. Make sure the little nubs on the pad fit into the piston when you put them back in.
Aug 13, 2008 at 6:07 AM
