Tech bulliten on front brakes found, read here!
FRONT BRAKE SQUEAL/SQUEAK NOISE - VEHICLES BUILT 8/1/2003 THROUGH 5/30/2005 TECHNICAL SERVICE BULLETIN Reference Number(s): 05-14-1, Date of Issue: July 25, 2005 Related Ref Number(s): 05-14-1 ARTICLE BEGINNING DESCRIPTION FRONT BRAKE SQUEAL/SQUEAK NOISE - VEHICLES BUILT 8/1/2003 THROUGH 5/30/2005 ISSUE Some 2004-2005 Freestar/Monterey vehicles built 8/1/2003 through 5/30/2005, may exhibit a front brake squeal/squeak that occurs continuously. ACTION Replace the front brake pad linings with a new Service Kit. Refer to the Instruction Sheet in the Kit. PARTS INFORMATION
FORD: 2004-2005 Freestar MERCURY: 2004-2005 Monterey NOTE: THIS TSB DOES NOT APPLY TO NORMAL BRAKE SQUEAL/SQUEAK CONDITIONS THAT OCCUR ON FIRST (MORNING) BRAKE APPLICATION, AND/OR INTERMITTENT SQUEAL INDUCED BY COLD, HEAT, WATER, MUD AND SNOW CONDITIONS.
Page 1 of 2 FRONT BRAKE SQUEAL/SQUEAK NOISE - VEHICLES BUILT 8/1/2003 THROUG...
Mar 28, 2009 at 12:23 AM
