2005 Ford Freestar coolant leak
2005 FORD FREESTAR
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIGPATOUX27
sorry i am french so i will try to explain the best that i can. i buy a 2005 ford freestar with a 4.2 on it.he lost some coolant just when is hot and just a little so i check it and it look like it came from the front passager side,near the crankpully. so maybe the waterpump but non,she is ok.so i cannot really see but it look like comming from the place where we put the oil filter (or up) do it's possible?do there is some coolant on this place? is it a oil cooler? do the engine imself can be broke crack or something even if it run well?and if not what it can be?? thanks before
Dec 6, 2009 at 11:45 AM
  • 31,937 POSTS
Hi there,
What you need to do first is go to a mechanic and ask for a cooling system pressure test, this test will only take a few min, and it will locate any external coolant leaks, start here.
mark (mhpautos)
Dec 6, 2009 at 12:59 PM
