2005 Ford Freestar Camshaft Position Sensor and Speed Senso
MUSTANGNY75
  • 2005 FORD FREESTAR
Engine Mechanical problem
2005 Ford Freestar 6 cyl Front Wheel Drive 42000 miles
Advance Auto retrieved the codes P0715 and P0340 from my Freestar. Where are these sensors located and are they difficult to replace?
Tuesday, February 16th, 2010 AT 12:19 PM
MERLIN2021
  • 17,250 POSTS
There is a Technical Service Bulliten about water intrusion into the PCM, and the tranny vent tube, it's 16 pages long so I will email you a PDF file with the entire TSB. Dont replace anything until you read this, it may be covered by Ford under Fed emisions. Call Ford first!
Tuesday, February 16th, 2010 AT 4:11 PM
MELLIOTT81
Could you email menthis bulletin also. I am having these same codes and problems!
Saturday, December 6th, 2014 AT 8:36 AM
