2005 Ford Freestar Brakes
DON LAWRENCE
Brakes problem
2005 Ford Freestar 6 cyl Front Wheel Drive Automatic 81000K miles
I have replaced the master cylinder but when I keep constant pressure on the brake pedal it gradually touches the floor.
Appreciate any help with this.
Don
Sep 28, 2009 at 3:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
was it doing this prior to master cylinder replacement?
Sep 28, 2009 at 4:12 PM
DON LAWRENCE
Yes it was.That is reason I changed the master cylinder
Sep 30, 2009 at 12:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check for a vacuum leak at the brake booster. the booster itself will need tested to.
Sep 30, 2009 at 12:15 PM
