2004 Ford Freestar Van will not go into gears....
19,800 MILES • 6 CYL • FWD • AUTOMATIC
MISSYBURROUGH
I put the van into Drive, Reverse, All the gears, and get no movement. The motor will rev-up, and that is all it does. The were no prior problems, linkage works, ......And I need a diagram of the fuses, relays, and sensors. I have lost the owner's manual.....
Feb 7, 2010 at 4:10 PM
OCCHOPPER
im having the same problem have you by any cahnce figured out what it could be or do you know how to locate the PCM cover because the problem may be a result of water leaking into and inproperly secrured cover. thanks let me know.
Mar 16, 2010 at 9:38 AM
