2004 Ford Freestar Rear door latch stuck in locked position
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
AKREMA
My rear door is stuck in the closed and locked position. I removed the door cover panel and can access the latch mechanism. I need to manipulate it to unlock it so I can open the door. Is there any way to do this? Please help!
Apr 27, 2010 at 9:06 AM
2 LINSEY
  • 287 POSTS
Hi akrema, Thank you for the donation. Use a flash light and a small screw driver or pic and find the rod that connects the latch to the lock rod pin. The part your are looking for should have a door lock acuator connected to it which is electric so it will have a connector and wires going to it. Mannualy push the latch over. Good luck
Apr 28, 2010 at 6:44 AM
