2004 Ford Freestar Crusie Control
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAYB1972
My crusie control wont turn on, where do I start?
Feb 13, 2009 at 2:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspecting fuses and also inspecting wiring at the cruise control module.
Thanks for using 2CarPros.com!
Feb 13, 2009 at 3:34 PM
JEPOHLMAN
  • 6 POSTS
Is a bad cruise disconnect switch on the bottom of the master cylinder.
When you have the hood open you'll see it sticking down vertically from the master cylinder and they cost about $35.
Be careful not to cross thread the switch when you put it in or you'll have to replace the master cylinder also.
Feb 21, 2009 at 5:47 AM
