Steering porblem
PIPEFITTER74
Six cylinder two wheel drive automatic 135,000 miles.
I just bought this vehjicle. Recently and now when you steer, the wheel is very hard to turn the first quarter turn than it loosens up the next quarter than gets stiff again. i checked the power steering fluid and there was not any. i looked for leaks around the pump and rack and pinion and there was not any! i added fluid but it did not help and did not leak out, still full. do you think the pump is bad or the rack and pinion? i appreciate your time and look forward to your thoughts on this!
Jun 16, 2009 at 1:09 PM
DOCFIXIT
  • 18,828 POSTS
Check the rack boots to tie rod ends see if they have fluid in them. When you filled resevior did you move steering wheel lock to lock several time to bleed air?
Thanks for donation.
Jun 17, 2009 at 3:49 AM
PIPEFITTER74
No fluid in rack and pinion boot filled with fluid moved steering to lock several times still was hard to steer.
Jun 17, 2009 at 12:17 PM
DOCFIXIT
  • 18,828 POSTS
Question is where did fluid go? Pump making any noise ie. whine? If no most likely rack faulty. Try jacking front wheels off ground see if it gets free.
Jun 18, 2009 at 3:07 AM
THREESPRUCE
Had same problem, but no leak, on my 2004 Ford Freestar. I figured it was the universal joint on steering column at the rack since it was hard about every quarter turn. I could not see how the pump or rack would cause this. I sprayed the joint liberally with Releasall, wiped it down then worked the wheel side to side about ten times then sprayed it with WD40 and turned it side to side again. I could feel it freeing up as I did this. Then I let it sit for about ten minutes and finished off with a liberal coating of sprayed on white lithium grease. Presto, works like new again!
Since it is winter here and I do not have a garage, I did all this from under the hood, without removing anything, When spring arrives I will get under the van and clean it up again and pack some good axle grease in there. Cost virtually nothing and about thirty minutes of my time.
Hope this might help some other souls.
Jan 24, 2015 at 8:09 AM
THUBTEN
Same problem; it was the U joint on the steering shaft. got a one inch paintbrush and duct taped it to a two foot long stick and painted PB Blaster all over it while my son ran the steering all the way left and right. Let her rest for an hour then repeated with 30 wt oil. Then repeated slathering the whole joint with grease. You can reach it shining a light through right to the upper right of the engine. easy fix.
Apr 18, 2016 at 12:47 PM
WWSNOWBIRD
Sudden loss of power steering, parked my 04 4,2l freestar friday, and monday morning powersteering was out...
Very hard to turn any speed any surface any direction. trouble was the belt idler jumped over a locking tab (possibly there to ease installation keeping the spring compressed) and serpentine belt was very loose...I puled on the belt and pryed the tab, clik! everything fell back in place.
Note, at startup this morning engine went a bit like back firing, this may have shocked the belt and pushed tensionner outward.
Apr 14, 2019 at 10:49 PM
Thanks for the info. Feel free to come back if you need any assistance. We are here to help. Thanks
Apr 15, 2019 at 4:43 AM
