2004 Ford Freestar
66,400 MILES • 6 CYL • FWD • AUTOMATIC
PAT KIRCHNER
Fuel system cleaning was done at 65,000 miles since that time the vehicle "hiccups" when going 45-65 mph.Had fuel filter replaced, trans filter kit installed,cabin air filter replaced. All computer tests were completed and found okay.It appears that the "hiccups" take place when there is a light to heavy snowfall or rain. Both the mechanic and this owner are frustrated. I have taken several trips of several hundred miles and the van drove beautifully in temps between -10 and 40 degrees ??????
Feb 2, 2008 at 4:02 AM
2CARPRO JACK
  • 11,533 POSTS
Define "hiccups" is it like an engine miss? or is it downshifting? Has the van ever been tuned up? moisture could be acausing a misfire due to bad plug wire.
Feb 7, 2008 at 7:15 AM
