Ford Focus Catalyst Below Threshold
FUELLENBACH
  • 6 POSTS
My check engine light came on so I borrowed a friends code reader to help me find out what the problem was. Ufortanatly the answer it gave me I don't understand. It told me the Catalyst Efficiency is Below Threshold. What the F*** does that mean?
May 20, 2007 at 12:22 PM
CLEAVAGE4U
  • 69 POSTS
Now is that any way to go talking on a perfessunal four em. I know just what you meant by that. Those little ol asss tricks don't fool me.
May 20, 2007 at 2:07 PM
RUDPRO
  • 224 POSTS
it can be a few things but it probably means your catalytic convertor is bad. I would clear the code and see if it comes back. If it does you may want to call a Ford dealer. They have to warranty the emissions system for 70,000 miles I believe.
May 20, 2007 at 6:08 PM
SERVICE WRITER
  • 9,123 POSTS
Converter is 8yr/80,000 miles OEM warranty. Other emissions warranties vary depending on part.
May 21, 2007 at 1:12 AM
FUELLENBACH
  • 6 POSTS
I cleared the code (which was P0420) but when I did that it didn't come back. Instead it showed a yellow light stating there was still a problem but now it didn't know what the problem was.
Also, you mentioned warranty which I will call the dealer about but my car already has 78,000 miles on it. How much would it be around to fix a converter problem for my car?
May 21, 2007 at 3:40 AM
RUDPRO
  • 224 POSTS
The convertor is warrantied for 80,000 miles. Take it to the dealer fast.
May 21, 2007 at 4:26 AM
FUELLENBACH
  • 6 POSTS
Thank you!
May 21, 2007 at 4:47 AM
Suggested Repair
P0420 (catalyst efficiency below threshold) often indicates a failing catalytic converter. Clear the code and see if it returns. With about 78,000 miles, take the car to a Ford dealer promptly to check the OEM catalytic converter emissions warranty, commonly cited as 8 years/80,000 miles.
Conversation Summary
The owner of a Ford Focus ZX3 2.3L had a check engine light and a code reader report catalyst efficiency below threshold, later identified as P0420. Experts said the catalytic converter is the likely cause and advised clearing the code to see if it returns, then contacting a Ford dealer about the emissions warranty. The owner cleared the code; it did not return as P0420, but a warning light remained without a specific code. With 78,000 miles, the owner was told the converter is covered to 80,000 miles and to go to the dealer quickly.
