Ford Focus Catalyst Below Threshold
Also, you mentioned warranty which I will call the dealer about but my car already has 78,000 miles on it. How much would it be around to fix a converter problem for my car?
Suggested Repair
P0420 (catalyst efficiency below threshold) often indicates a failing catalytic converter. Clear the code and see if it returns. With about 78,000 miles, take the car to a Ford dealer promptly to check the OEM catalytic converter emissions warranty, commonly cited as 8 years/80,000 miles.
Conversation Summary
The owner of a Ford Focus ZX3 2.3L had a check engine light and a code reader report catalyst efficiency below threshold, later identified as P0420. Experts said the catalytic converter is the likely cause and advised clearing the code to see if it returns, then contacting a Ford dealer about the emissions warranty. The owner cleared the code; it did not return as P0420, but a warning light remained without a specific code. With 78,000 miles, the owner was told the converter is covered to 80,000 miles and to go to the dealer quickly.
