Ford Focus
ANNMCCABE
  • FORD FOCUS
I have a 2001 Ford Focus 67000 miles if I let the engine idle for a little bit it overheats now it wont start and I thought the battery need replaced but I had it jumped and it died again and was running hot What is the problem? Please help
Thursday, June 22nd, 2006 AT 10:30 AM
ORIGINALMAZDAWG
You might want to check your fan(s). Make sure they are working "full blast" when your car is hot or overheating. If not then your problem might be the fans or relays for them. I had a problem with my '01 ZX3 not starting, after eliminating the relays, battery, and the starter (by getting a new one for a pretty penny), it turned out to be the battery cable on the positive side. Looked good from the outside, but had corrosion on the inside, cut the end off, replaced the terminal and soldered back together. Hope this helps.
Tuesday, October 10th, 2006 AT 11:18 AM
