2001 Ford Focus Idle Jerk After Belt
VARIAN
The car is a Ford Focus 2001 1.6L zeetec automatic with 75000 miles on it. After having the car serviced the engine does not operate smoothly when in idle. The tachometer gage is at 900 rmp and it jerks up and down slightly, the jerking increases when the car is put in "Drive". When the car is in "Drive" but standing still it starts to rock forward and back. In addition when in a traffic jam in low speeds the rpm goes down suddenly to 400 and it looks like the car is going to stall but it doesn't, this happens randomly. When driving at speeds above 20mph the car works fine.
At service the Timing belt of the engine was changed, the spark plugs (motocraft orginal) oil, oil filter and air filter. Before the service the car was fine.
May 30, 2007 at 5:06 AM
RUDPRO
  • 224 POSTS
You better take it back there and raise some hell. They obviously didn't do something right with replacing the timng belt. Tell them to fix it or you'll take legal action against them.
May 30, 2007 at 6:29 PM
VARIAN
But how can I prove to them that they caused the problem?
May 31, 2007 at 12:22 AM
2CARPRO JACK
  • 11,533 POSTS
You dont have to prove anything.. you came in for scheduled maintenance and got your car back running poorly. Be the squeeky wheel and they will grease you
May 31, 2007 at 1:17 AM
2CARPRO JACK
  • 11,533 POSTS
Just explain to them that I came in for maintenance, now my car runs poorly. Had this been a problem in the first place, I would have addressed it along with the maintenance
Jun 1, 2007 at 12:18 AM
VARIAN
I took the car to the shop, they checked the car with a Texa computer and found no errors in the ECM. In addition they cleaned the bore of the throttle housing. This did not solve the problem. Now I am at a point that I think this garage does not have the technical expertise to solve the problem so I am thinking taking the car to an Official ford garage. I did some research and found in the manual that the Oil filter for the car has to be a Motocraft EFL-600, they installed a smaller filter in size - the EFL-134. Could this be causing the problem?
Jun 5, 2007 at 6:49 PM
2CARPRO JACK
  • 11,533 POSTS
Not likely. Im guessing they might have missed the cam timing when doing the belt. After Ford diagnoses it , get back to me.
Jun 6, 2007 at 12:59 AM
Suggested Repair
Have a Ford dealer or qualified shop recheck the timing belt installation and cam timing, which may have been set incorrectly during the recent service. The smaller oil filter is unlikely to cause this idle jerking.
Conversation Summary
A 2001 Ford Focus 1.6L automatic began jerking at idle and rocking in Drive after a timing belt, spark plug, oil, and filter service, and sometimes dropped to about 400 rpm at low speed without stalling. It ran normally above 20 mph. The shop found no ECM codes and cleaning the throttle bore did not help. Experts said the wrong oil filter was unlikely and suspected missed cam timing, recommending Ford diagnosis.
