ford focus check engine light p0460...?
156,000 MILES
LUISITO123
I did not have a check engine light, until I went to the gas station an put gas. After putting gas (maybe 5 minutes), the check engine light came on. Could it be due to a bad gas cap? I mean my parameter cluster works fine and all the readings work fine too (speedometer, gas, oil, etc). I have changed my gas cap once, which i replaced it with an aftermarket one? could that be the problem,,,,
Oct 20, 2013 at 6:43 AM
  • 75,988 POSTS
Go to Autozone and have them scanned it-its free of charge and go from there-
Oct 20, 2013 at 7:03 AM
LUISITO123
I got that code...p0460...and i have a code scanner
Oct 20, 2013 at 9:32 AM
HMAC300
  • 48,601 POSTS
Look for the flexible fuel badge on the vehicle. If customer complains of MIL illumination with code PO460 and inoperative fuel gauge unplug flexible fuel sensor.
You will have to remove the radio and heater control head which takes about a minute. Sensor is a six wire plug bolted to dash support behind radio.
If gas gauge goes from zero to full or over full you need a new flexible fuel sensor.
Part number: YF1U-14a069AA
Oct 21, 2013 at 12:05 AM
