I have an ABS module for Ford Focus 2012, can i use it for the car listed above?
Mar 12, 2019 at 8:17 PM
✓Experienced Mechanic
Yes, they should work please upload the part numbers of both units so I can check to be sure. here are the instructions and diagrams on how to change the ABS unit out. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Mar 14, 2019 at 6:20 AM
GALANGFA
MEMBER
Hi Ken,
Thanks for the help.
The PN for focus is BV61-2C405-AG and the PN for fiesta is AV59-2C405-EA.
I have tried to install the ABS module on my car in Ford service center but the it cannot synchronized.
Advise please?
Thanks,
Galang
Mar 14, 2019 at 11:04 AM
Yes, the modules are not interchangeable, you will need the correct unit. Please let us know what happens.
Mar 17, 2019 at 8:12 AM
GALANGFA
MEMBER
ABS module on my car was fault,,and i bought ford focus abs module. Do you have related document how to repair the ABS module?
Mar 17, 2019 at 1:37 PM
These wear out internally, I would replace it. Please let me know what happens.
