My car starts to wobble if my speed increases above 65 mph. Do I need new tires or is there something else going on?
Dec 16, 2008 at 1:53 AM
JDL
✓Experienced Mechanic
You may need to have the front end alignment checked?
You might jack-up the tires, one at a time, shake the tire up and down and in and out, run your hand around the thread see if you feel anything? Put the vehicle on level ground, set the e-brake, block the wheels, to jack-up the tire, be safe.
Just a thought, you might rotate the front tires to the rear, see if it makes any difference
