2007 Ford Focus A/C Recycle switch
2007 FORD FOCUS
37,000 MILES • 4 CYL • FWD • MANUAL
HAN_CHUA
My recycle switch is on, the light indicator is on, but the airconditioning unit will keep on sucking outside air. can anyone help me with this. thak you
Oct 28, 2010 at 2:31 AM
WRENCHTECH
  • 20,761 POSTS
There should be a vacuum actuator for the door. Check it and the vacuum lines to it. Remember, you will not get recirc air if the mode is set the floor/defrost or straight defrost.
Oct 28, 2010 at 2:47 AM
HAN_CHUA
followed your instructions
-I checked the actuator and it is fine working properly.
-I checked the suction door and found out it was not moving together with the actuator.
-Fixed the suction door.
-Problem solved.
THANK YOU SO MUCH
Oct 28, 2010 at 8:50 AM
WRENCHTECH
  • 20,761 POSTS
Your welcome, Positive feedback is appreciated.
Oct 28, 2010 at 8:55 AM
PDPETE24
I have the same problem on my 2004 focus. Where do you find the actuator?
Dec 3, 2010 at 8:06 PM
