2006 Ford Focus steering
36,000 MILES • 4 CYL • 2WD • MANUAL
RSMITH84747
the steering wheel shakes when driving above 20mph
Feb 7, 2009 at 12:05 AM
SAWMASTER88
  • 38 POSTS
The problem sounds like a suspension problem. I would look at either the tie rod ends, or the ball joints. If either are broken or severly worn the could easily cause the shaking problem. The other thing I can think of is possibly the stabilizer links. Double check with the dealer on any possible recalls having to do with the parts. I know the early 2000, and 2001 had the front struts, coil springs and stabilizer links recalled. Hope this helps and good luck.
Feb 9, 2009 at 2:00 PM
