2006 Ford Focus Squilling and leaking pump
65,000 MILES • 4 CYL • FWD • AUTOMATIC
TAUNA
What is the cost to get the steering pump replaced?
Dec 24, 2009 at 6:26 AM
JAYBIN82
  • 44 POSTS
if you take it somewhere it depends on how much work is involved. call around. its always much cheaper to fix it your self. go to your local auto parts store get the part, or even cheaper, the salvage yard. either way make sure you have the gasket too. if its right on top it should be a easy fix.
Dec 24, 2009 at 6:48 AM
