2006 Ford Focus steering
RSMITH84747
  • 2006 FORD FOCUS
  • 4 CYL
  • MANUAL
  • 36,000 MILES
The steering wheel shakes when driving above 20mph
Saturday, February 7th, 2009 AT 8:05 AM
SAWMASTER88
  • 38 POSTS
The problem sounds like a suspension problem. I would look at either the tie rod ends, or the ball joints. If either are broken or severly worn the could easily cause the shaking problem. The other thing I can think of is possibly the stabilizer links. Double check with the dealer on any possible recalls having to do with the parts. I know the early 2000, and 2001 had the front struts, coil springs and stabilizer links recalled. Hope this helps and good luck.
Monday, February 9th, 2009 AT 10:00 PM
