2006 Ford Focus Heater/Air Conditioning is not blowing at a
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
KLOR
My heater recently began making odd clicking noises, and every now and then would shut down, then come back on in a few minutes. I assumed the engine might not be getting enough coolant, so I topped that up and figured it would be all good. However today my heater stopped blowing air entirely hot or cold. I have checked the fuses and they are fine, all other electrical components such as rear window defroster, etc. work fine. What might the problem be?
Dec 17, 2008 at 4:47 PM
DAVE H
  • 13,383 POSTS
you need to check Blower Motor Resistor....Behind center of dash. See Fig. 34 also check wiring to switch the switch may be at fault ?
https://images.2carpros.com/forum/automotive_pictures/266999_res_1.jpg
Dec 17, 2008 at 11:58 PM
