2006 Ford Focus electrical cooling fan
98,000 MILES • 4 CYL • FWD • AUTOMATIC
TIMCAUDLEINNC
why is the electrical cooling fan is not coming on?
Dec 8, 2009 at 5:19 AM
BMRFIXIT
  • 19,053 POSTS
It should come on only when needed
if engine overheating and fan not coming on
check fuses 1st and relays
check coolant fan switch and coolant fan motor
checking for code in most cases should help in pin pointing the troubled area
Dec 8, 2009 at 11:56 AM
