2006 Ford Focus Door ajar sensor
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
JMLINDEN
The door ajar sensor on my rear hatch continues to ring/buzz even those the hatch is closed and latched. The latch was malfunctioning but after spraying it with WD40 it works fine. However, the buzzer and light contiinue to ring. Is there a way to disconnect the sensor in the hatch latch?
Jan 5, 2010 at 4:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
thanks for the donation!
you can remove the rear hatch interior panel trim to access the door ajar switch located on the latch. if you was going to go through the trouble of removing all that though I would suggest just replacing the switch.
Jan 20, 2010 at 1:29 PM
