Thursday, October 28th, 2010 AT 2:01 PM
What is required to change the ATF on a Focus? I read a post on eHow that said to just disconnect the tube that goes into the radiator, start the engine and let the auto trans fluid be pumped out into a pan. Then add the new fluid through a filler tube next to the AT dipstick. Is that it? It's okay to run the engine without AT fluid?
