2005 Ford Focus replacing front right side marker lights
114,250 MILES • 4 CYL • 2WD • MANUAL
NEWJERSEY7
how to I remove and install my front right side market light unit in my 2005 ford focus?
Feb 7, 2010 at 10:58 PM
ERNEST CLARK
  • 1,730 POSTS
You have to gain access to the back of the unit. If you can't do this from under the car, then you'll have to remove the black plastic wheel well cover and reach through there.
You'll have to take off the wheel first, then remove the bolts that run along the perimeter of the wheel well cover.
You may only have to remove the front set of bolts, as the plastic is flexible. But be careful not to crack it.
If I've helped you, please take the time to vote for me as my reputation pays my bills. Thanx, Ernest.
Feb 8, 2010 at 11:13 PM
