2005 Ford Focus rear drum removal
27,000 MILES • 4 CYL • 2WD • AUTOMATIC
WILLIAM37
what size nut secures the rear brake drum?
Mar 13, 2009 at 7:09 AM
JNOVACK
  • 723 POSTS
usually a 30mm
Remove or disconnect the following:
Rear wheel
Wheel speed sensor, if equipped
Brake drum, bearing and spindle assembly.
To install:
Install or connect the following:
Brake drum, bearing and spindle assembly. Tighten the bolts to 49 ft. lbs. (66 Nm).
Rear wheel
Mar 15, 2021 at 12:41 PM
