2005 Ford Focus engine light, white smoke at startup
2005 FORD FOCUS
11,835 MILES • 4 CYL • FWD • MANUAL
BAMAKODAKER
I noticed the last several nights (summer, warm, car has been sitting for several hours) as I cranked my car to go home it would idle up, then it would surge up to a rather high idle (this is a change, don't remember a high idle like this), after a while it would drop back down to normal.
Last night coming home the engine light came on.
This morning when I cranked it up I noticed a good bit of white smoke come out of exhaust.
What is going on?
I must admit - I've done little more than change the oil and filters. Original plugs and wires. I regularly use fuel injector cleaner. I think I might have noticed recent a very slight drop in power at lower speeds going up a hill but not enough to be a real concern. Any help is appreciated.
bamakodaker
Jul 6, 2010 at 1:40 AM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Jul 6, 2010 at 2:34 AM
BAMAKODAKER
About the smoke - I've not noticed any from this vehicle before. It was white (lt. gray?) smoke that wafted around the car and continued on - not steam.
AutoZone did a scan;
Trouble shooting P2004
Definition
Intake manifold runner control (IMRC) stuck open
bank 1
Explanation
ECM has commanded the IMRC closed but detects it open
Probable cause
1 - short circuit condition
2 - damaged IMRC actuator or solenoid
3 - blocked vacuum hose
I found the IMRC/actuator below and behind throttle body. I watched the rod leading up from IMRC/actuator. As engine started the rod went down. After a second or so the rod came back up and the RMP's settled down. After 3-4 seconds the rod went back down and the engine went up to rather high RPM's. After about 2 seconds the RPM's started going down but the rod stayed down even as the RPM's went down to normal idle. I see nothing to indicate a short. I followed the vacuum hose under IMRC/actuator to where it joined another hose under manifold then hose went behind manifold. I saw no kinks or bends.
I really need to repair this myself as to $$. Not what I need 2 days before leaving on 800 mile round trip!
Any thoughts or suggestions greatly appreciated.
bamakodaker
Jul 7, 2010 at 8:13 AM
