2005 Ford Focus engine
136,000 MILES • 4 CYL • FWD • AUTOMATIC
YARDLINE-1959
While driving the motor well lose power and white smoke will come out the exhaust for a little and stop for a couple of days and start all over again. What maybe causes this problem
Feb 8, 2010 at 10:57 PM
ERNEST CLARK
  • 1,730 POSTS
White smoke from the tail pipe is a sure sign of coolant leaking into the cylinders of your engine.
Have you checked your anti-freeze level lately???
Coolant can get into your cylinders from a blown intake gasket, head gasket or both. And you'll soon experience overheating issues as well, if you haven't already.
Because your engine is a four cylinder, it is a lot easier to replace these gaskets. But only for mechanics, not people with no experience. And unfortunately, no mechanic will do this cheaply.
Feb 8, 2010 at 11:10 PM
