2005 Ford Focus clutch
KATHY.HALL
  • 6 POSTS
Transmission problem
2005 Ford Focus 4 cyl Front Wheel Drive Manual
my daughter was driving my car when the clutch peddle want go all the way down
Nov 22, 2009 at 11:17 AM
  • 31,937 POSTS
Hi there, you will need to establish if this is a mechanical problem with in the clutch or with the hydraulics and the master cylinder, i would open the bleeder and see if the pedal will travel to the floor with out any hard or tight spots, do this and report you findings.
Mark (mhpautos)
Nov 22, 2009 at 1:55 PM
KATHY.HALL
  • 6 POSTS
thats the problem it want go to the floor it stops half way down. it gets hard at the end.
Nov 24, 2009 at 5:28 AM
KATHY.HALL
  • 6 POSTS
what is a slavery
Nov 24, 2009 at 5:35 AM
  • 31,937 POSTS
You mean the slave cylinder, that is the cylinder on the transmission end of the clutch hydraulic system that actuates the clutch mechanism.
Mark
Nov 24, 2009 at 6:40 AM
