2005 Ford Focus
95,000 MILES • 6 CYL • FWD • MANUAL
BGOSSAL
my car a ford focus 05 plate when in 1st and 2nd gear i have to give it more revs to get moving than i would normally it is very sluggish in these gears and even in higher gears if i press down on the accelrator the revs will go up but the speed of the car will not and i have to bring it back down and speed up slowly
Feb 26, 2010 at 12:10 AM
  • 75,988 POSTS
Hesitation,lack of acceleration,chugging,bogging etc.
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 26, 2010 at 1:30 PM
