2004 Ford Focus vibration
78,000 MILES • 4 CYL • 2WD • AUTOMATIC
KPOPE
I am noticing vibration all the time but it gets bad when I am driving about 68 and higher. I though it might be my tires, but it vibrates when I am at a stop too. Any suggestions on what to check?
Mar 5, 2008 at 9:57 AM
SERVICE WRITER
  • 9,123 POSTS
May be 2 separate problem. The first one sounds like a wheel balance issue. The latter symptom may be related to debris caught in the rear engine roll restrictor. If the vibration seems a little more obvious in reverse at idle, then clean this area out and pick up a service sheild, part number 2M5Z-16102AA from the dealer and install it.
Mar 13, 2008 at 10:55 PM
