2004 Ford Focus NO SPARK
_COSENTINO
Engine Mechanical problem
2004 Ford Focus 4 cyl Front Wheel Drive Automatic
I just did a motor swap on my focus. all the wires are hooked back up, now i am getting no spark from my coil on plugs changed the camshaft sensor and the crankshaft sensor, still nothing
May 7, 2010 at 6:18 PM
BMRFIXIT
  • 19,053 POSTS
with key ON do you have check engine light on ?
you should
check for codes
May 7, 2010 at 10:37 PM
_COSENTINO
yes the check enginelight is on. i do not have a way to check for the codes,
May 8, 2010 at 3:30 AM
