2004 Ford Focus Engine misfires
140,000 MILES • 4 CYL • FWD • MANUAL
AC2211
Engine misfires on acceleration and also at idle.This problem has gotten progressily worse.
Jan 17, 2010 at 8:51 AM
  • 75,988 POSTS
An engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 17, 2010 at 2:05 PM
