2004 Ford Focus belt noise
81,000 MILES • 4 CYL • AWD • AUTOMATIC
RGARZA2290
when i step on the gas pedel and start accelerating a sqeaky noise starts up and it sound like a belt is squeaking. what could it be?
May 6, 2010 at 5:12 AM
RENAUDTN
  • 636 POSTS
Could be a bad belt, bad pulley (bearing), misaligned pulley, low belt tension causing the belt to slip on pulleys.
Here’s a little trick:
Spray the belt lightly with a spray bottle. If the noise level stops or decreases for a few seconds, then returns louder, a misalignment problem is likely. If the noise immediately increases after the belt is sprayed, slipping is likely.
If you determine the belt is slipping, check your tensioner.
May 7, 2010 at 4:52 AM
