I CANT SEEM TO FIND WHERE TO ADD FREON TO MY CAR. MY FORD RANGERS WERE EASY,SO WHERE DID THEY HIDE THE LOW PRESSURE FITTING?
Aug 9, 2008 at 3:00 AM
BAC512
MEMBER
the low pressure intake is inside the front passanger wheel well... you gotta take the plastic trim out of the wheel well to get to it..... probably easiest if you remove the tire first.
