2003 Ford Focus spark plugs
63,000 MILES • 4 CYL • 2WD • AUTOMATIC
LESLIEALTA84
I replaced the spark plugs and now the car wont start, went back to auto zone and gap the spark plugs still wont start, went back and got some spark plug wires and it wont start. so i took it all off since it was working before i replacced the spark plugs and it still wont turn on..
Feb 22, 2010 at 4:40 AM
  • 75,988 POSTS
Cranks but no start condition: Do below:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 22, 2010 at 11:48 AM
