2003 Ford Focus Refilling R134
EDULAY
Air Conditioning problem
2003 Ford Focus 4 cyl Two Wheel Drive Automatic
Where do I connect the refrigerant refill canister to the the A system, when recharging the AC system?
May 24, 2009 at 11:25 PM
ARGUS
  • 7 POSTS
Just noticed your question.....
If you haven't already done the job, the fill is typically done through the low-side valve when using a shop system.
Your low-side should be under the front bumper on the passenger side.
The high-side valve is just on the right as you are facing the car. just passed the fan shroud.
I've never use a DIY refill kit, but the manual should tell you which side to fill, high or low.
If it does, at least now you now which one is where.
(Please note: Not a mechanic....but have owned several 2001-2003 Ford Focus wagons.)
Jun 22, 2009 at 4:57 PM
