2003 Ford Focus Rear Drum Brakes shaking when braking!
91,800 MILES • 4 CYL • 2WD • AUTOMATIC
KEVIN0787
I just got my whole rear brake system done. New drums, brake shoes, and wheel cylinders (the old wheel cylinders were leaking). I got the car back and started driving it home, and noticed when braking that the car was now shaking! The shaking does not feel like it is coming through the steering wheel. It feels like it is the whole back end that is shaking now.
When I am applying the brake pedal now at low speeds (10mph or less), it feels like the brakes are only working half the time. I can feel that the brakes grab and release, grab, release, like they are only braking over half the braking surface.
Also, when I took the car in, the emergency/parking brake had pressure to it. I could pull it maybe a few clicks before it was tight. Now I can pull it all the way up without problem. Any ideas on what the shop did wrong that would be causing all this? I'd like to know what to kind of tell them so I don't have to go back to them several times to figure it out. Thank you!!
May 12, 2010 at 2:50 AM
  • 31,937 POSTS
HI there,
There will be high spots on the over the counter shoes that they have fitted, when new brakes and drums are fitted the shoes should be radius ground to suit the new drums, finding some one with this gear these days is a bit hard, your mechanic may have a contact.
Mark (mhpautos)
May 12, 2010 at 8:02 PM
