2003 Ford Focus neutral safrty switch
GARY G DAVIS
Electrical problem
2003 Ford Focus 4 cyl Front Wheel Drive Manual 16k miles
I turn key, all the dash lights work but absolutely no sound from under the hood, not a click or tick sound that might led you to think battery. I push start and it runs fine until Iturn it off. Then it starts again. Is it the neutral safety switcH? WHERE IS IT LOCOATED?
thanks Gary
Feb 9, 2008 at 9:53 AM
  • 75,988 POSTS
Is it the neutral safety switcH? WHERE IS IT LOCOATED? You don't have the NSS its not an automatic
Okay-find the clutch switch-follow the clutch pedal till you get to the switch disconnect it-and put a jumper wire between the terminals-attempt to start it-
Feb 9, 2008 at 9:57 AM
