The car runs rough under 1000 rpm, it comes to vibrate. The scanner tells me PO316 and PO304, cylinder 4 missfire. This start when I tuned up the car. change spark plugs, leads, filters and clean injectors, the new cables has 2.35, 2.90, 3.74 and 4.24 X 10 K ohms. I got some liquid on the exhaust. Hoe can check the ignition module or coil?
Thanks in advanced.
Thanks in advanced.
Dec 9, 2007 at 11:44 AM
