2003 Ford Focus misfires
ISYS
Engine Performance problem
2003 Ford Focus 4 cyl Front Wheel Drive Automatic 87k miles
once engine warms up it starts to misfire and to a
point to were engine quits replace crankshaft sensor
& coilpack compture codes of 2cyl misfire & 3 cyl misfire then finally random misfires engine cools for a
while and runs fine for a good while then starts to
misfire again sparkplug wires are good7
Jan 10, 2009 at 2:47 PM
2CARPRO JACK
  • 11,533 POSTS
When it gets hot and runs poorly, use a meter to test across the injectors for 2,3 and then compare that reading to 1,4 and see if those injectors are bad. Otherwise it will be something related to those 2 cylinders being next to each other.Usually 2,3 are on the same side of the coil and that would take care of it.
Jan 10, 2009 at 11:14 PM
