2003 Ford Focus leaking coolent
16,000 MILES • 4 CYL • FWD • AUTOMATIC
RSTOODLEY
2003 ford focus has a coolent leak. I have been trying to find it for days. All the hoses and rad seem to be fine.
filled the Reservoir twice in about four days. looking at the bottom of the engine I can see coolent but cannot find where it is coming from. I have borrowed a pressure tester from a friend to apply more pressure to the system. How much Max. pressure can be applied to this system? Is 25 psi ok for a test?
Mar 13, 2008 at 3:29 AM
SERVICE WRITER
  • 9,123 POSTS
Don't exceed 15 pounds. That should be plenty to cause the leak. You may find good lighting and mirrors to be helpful.
Mar 13, 2008 at 10:50 PM
