Engine Performance problem
2003 Ford Focus 4 cyl Two Wheel Drive Manual
hi, i have a 1.4 focus and vehicle is ok on idle but when in 1st or 2nd gear on pull away it lacks power, when speed does get up it will plod along ok but if you need a little gas it starts to lack power. i do not believe it is a misfire as tick over is ok and recently replaced coil. it also has full service history. i suspect the catalyst as i have been told that when i replaced the coil due to misfire it can sometimes take the cat out and i get a rattle from the exhaust when revving sometimes.
Nov 16, 2008 at 1:14 AM
