2003 Ford Focus idiot lights
2003 FORD FOCUS
44,000 MILES • 4 CYL • FWD • AUTOMATIC
FCADHC
on my focus when i turn the car off the air light bag and oil light flash on real dim. also my key fob wont work. and the dome light keeps going on every so often.there is also a chime that goes off about every 20 seconds or so. when i start the car the lights go off and it all seems to work fine.
Jul 14, 2010 at 2:02 PM
  • 110,244 POSTS
You have a bad ground. Check the main ground to the engine block and also check for damaged body ground straps.
Jul 16, 2010 at 4:54 PM
