2003 Ford Focus I lose heat
122,000 MILES • 4 CYL • FWD • AUTOMATIC
RICHMICHAELS
why do I lose heat when I get to a red light or slow down in traffic? I seem to get heat while i've been driving for a while, but like I said, it slowly cools down while I come to a stop. The Fan works no problem, I'm getting air into the car, but it's not HOT air... Can anyone tell me WHAT's going on and how I can fix it??
also, my heated seat sees to have stopped working. I checked the fuse underneath the steering column and it looks just fine. Could these two "eat" issues be related??
Any help is greatly appreciated
Cheers,
M.R
Feb 25, 2009 at 2:36 PM
  • 75,988 POSTS
Check the thermostat and also the heater core if its clogging up also if it has a heater control valve-if not could be an air mix/blend/mode doors and vacuum/actuator problems and HVAC control module
Its two different problems.
Feb 25, 2009 at 5:50 PM
JKIRKERX
My heater just started doing the same thing. When the fluid is low, there's not enough to make it into the heat exchange inside the car. I added 1/2 a gallon, and it worked fine, but there is leak somewhere, hope it's not a bad heater core.
Feb 28, 2009 at 3:59 PM
