2003 Ford Focus Horn Problem
79,000 MILES • 4 CYL • 2WD • AUTOMATIC
KOHAWKS
my 2003 ford focus wagon horn stopped working.
1. I checked the fuse, and the fuse is fine.
2. I removed the horn and tried the horn attached to a seperate battery, and the horn sounded fine.
3. I'm scared to look at the steering wheel because I don't want to set off or mess with the air bag.
What is the best next step for me?
Jul 19, 2009 at 8:02 AM
BANDAGEBUM
Does the horn sound with the ignition off with the key out?
If so check that the steering column is earthed properly.
There should be a wire earthing it somewhere at the base or near the UJ.
Jun 16, 2011 at 8:26 AM
  • 75,988 POSTS
Check and test or swap the horn relay for a like one and see what happens
Jun 16, 2011 at 8:34 AM
CJ MEDEVAC
  • 11,000 POSTS
Forget the wimpy factory toy
No need to mess with steering wheel!
Want to be in Command in a bad situation?
Install a real horn!
The Medic
Jun 16, 2011 at 11:04 AM
  • 75,988 POSTS
Horn relay okay-time to disarm the air bags and get into the horn button/switch in the steering wheel-Let us know
Jun 16, 2011 at 1:27 PM
